How to change Timezone on ALE from CLI
MVP
MVP
Q:
How to change Timezone on ALE from CLI ?
A:
There are a bunch of files stored by region in the following directory:
/usr/share/zoneinfo
we can check this and find the one which matches our region. Then we have to create a symbolic link from /etc/localtime
For Example if our timezone region is Amsterdam, we can follow the below steps to update the timezone,
# rm -f localtime
# ln -s /usr/share/zoneinfo/Europe/Amsterdam /etc/localtime
# /etc/init.d/ale-jwebapp restart
To check the time we can use the below command,
# date
Version history
Revision #:
2 of 2
Last update:
‎10-25-2016 12:38 PM
Updated by:
Labels (1)
Contributors
