Monitoring, Management & Location Tracking
How to collect diagnostic tar logs from CLI of Airwave
Environment         This applies to all versions of Airwave
We can collect the diagnostic.tar.gz from CLI by running the below command.
[root@localhost mercury]# diagtarball
The output of the above command as ran on AMP-7.7.x version:
Gathering diagnostic information, this may take a few minutes.
diag_tarball_2011-03-04_03-03-12.tar.gz created.
This file will be present under the /tmp directory.
The output of the above command as ran on AMP-8.0.x version:
/var/ampcli/user/diag_tarball_2014-08-25_20-14-51.tar.gz created.
The file will be present under /var/ampcli/user directory.
Once the file is generated, users can copy it off the server using WINSCP utility.
Version history
Revision #:
1 of 1
Last update:
‎11-12-2014 10:23 AM
Updated by:
Labels (1)
Contributors
