Monitoring, Management & Location Tracking
How to disable IPv6 by modifying /etc/modprobe.conf ?
Question   How to disable IPv6 by modifying /etc/modprobe.conf?
IPv6 is not used by the AirWave server. If you'd like to disable it for some reason, do the following:
Edit the file:
/etc/modprobe.conf
Add the following line to the end of the file:
options ipv6 disable=1
...then reboot the server:
# reboot
Version history
Revision #:
2 of 2
Last update:
‎06-26-2014 03:49 PM
Labels (1)
Contributors
