Monitoring, Management & Location Tracking
How to disbale nmap scans done by Airwave on the network
Question- Airwave is doing nmap scans on the network
Environment- Airwave monitoring/managing Aruba or any other supported vendor devices
 Answer- Airwave has a module called Rapids, which Identifies or finds the rogue devices on the network. To find the OS of those rogue devices, airwave will do a nmap scan on the network automatically. This feature is configurable from the Airwave GUI --> Under Rapids setup page, as shown below:
We could set this option to no, for airwave to stop doing nmap scans.
Version history
Revision #:
1 of 1
Last update:
‎04-05-2015 03:05 AM
Updated by:
Labels (1)
Contributors
