How to enable SSH and SCP on IOS APs
Before changing the "Cisco IOS Config File Communication" setting on the Groups | Basic page add the following lines to the template for the device:
To Enable SSH:
ip domain name mydomain.com
ip http secure-server
%certificate%
To enable SCP :
aaa new-model
aaa authentication login default [local | group tacacs+]
aaa authorization exec default [local | group tacacs+]
ip scp server enable
You must make these changes to the device's running-config either by having AMP push a config containing the changes to the device using TFTP and then having AMP reboot the device, or by going out to the device itself and modifying the device's running-config directly.
After the changes are in the devices running-config, change the setting on the Groups | Basic page and have AMP push the config to get a Good configuration.
Version history
Revision #:
1 of 1
Last update:
‎06-10-2014 03:16 PM
Updated by:
Labels (1)
Contributors
