Monitoring, Management & Location Tracking
How to enable controllers to send UCC data to Airwave
Airwave 8.0.x  has a new feature, which shows the UCC (lync call info), under home --> UCC tab. for this option to work, we need to have Airwave code 8.0 + and AOS 6.4 +
Environment : Airwave monitoring/Managing AOS devices only.
1. We need to enable the below option from AMP setup --> general page:, on airwave.
2. we need to make sure, we add Airwave as a mgmt-server on the controller, as shown below:
for example:
(Controller) #show running-config | begin mgmt-server
Building Configuration...
mgmt-server type amp primary-server 192.x.x.x profile default-amp
so, that the controller can send the AMON information to Airwave without any issues.
please find the command below to add Airwave as a mgmt.-server on the controller
# configure terminal
(config)# mgmt.-server type amp primary-server <ip address> profile  <profile name>
the default profiles available on controllers are below:
default-ale
default-amp
we could see the default profiles by doing the following:
# show mgmt-server profile ?
Mgmt Config profile List
Name         References  Profile Status
default-ale  0           Predefined (editable)
default-amp  0           Predefined (editable)
Total:2
1.  We need to make sure if the AMON port is allowed between the controller and airwave, UDP port 8211
2.  need to confirm in the controller profile for mgmt-server, UCC Monitoring is enabled, as by default it will be disabled.
#show mgmt-server profile default-amp
Mgmt Config profile "default-amp" (Predefined (editable))
Parameter       Value
Stats           Enabled
Tag             Enabled
Sessions        Enabled
Monitored Info  Disabled
Misc            Enabled
Location        Enabled
UCC Monitoring  Disabled
AirGroup Info   Disabled
we need to manually enable it by doing this:
 #configure t
Enter Configuration commands, one per line. End with CNTL/Z
 (config) #mgmt-server profile default-amp
 (Mgmt Config profile "default-amp") #uccmonitoring-enable
 (Mgmt Config profile "default-amp") #exit
 (config) #show mgmt-server profile default-amp
Mgmt Config profile "default-amp" (Predefined (changed))
Parameter       Value
Stats           Enabled
Tag             Enabled
Sessions        Enabled
Misc            Enabled
Location        Enabled
UCC Monitoring  Enabled
Version history
Revision #:
1 of 1
Last update:
‎11-04-2014 12:17 PM
Updated by:
Labels (1)
Contributors
Comments
MRodden
Is there a method to enable UCC data to AMP in an IAP environemnt?
