AMP can be configured to do detailed logging of the RADIUS accounting packets it receives. To do so AMP creates a directory for that device under:/var/log/radius/radacct/To enable this feature please do the following:1. Using nano (or your favorite text editor), edit the file:/etc/raddb/radiusd.conf Search on "accounting {" where you will find the following text:accounting {## Create a 'detail'ed log of the packets.# Note that accounting requests which are proxied# are also logged in the detail file.# detail2. To enable detailed logging, un-comment the last line above by removing the # from in front of detail. It should look like this after editing:accounting {## Create a 'detail'ed log of the packets.# Note that accounting requests which are proxied# are also logged in the detail file.detail3. Save the file and run the following command to restart radiusd:service radiusd restart
