How to enable/disable Aruba Central setting for MAS switches from Airwave Switch configuration?
Yes, Aruba Central support settings for Aruba MAS Devices running version 7.3.2.0 and later.
To enable Aruba Central Configuration in AirWave:
1. Navigate to Groups > Switch Config > System Features > General Config > Aruba Central Configuration. 2. Select Yes to enable or No to disable. 3. Click Save. This feature is enabled by default.
