How to get Clarity data on Airwave
What are the things to check for getting clarity data on Airwave
Airwave version : 8.2
Controller version : Should be 6.4.3.x or newer
Configuration which needs to be checked on the controller
  • Make sure Airwave is listed under mgmt-server list. We can run the below command from Controller CLI to verify it
> show mgmt-servers
  • Make sure the inline stats are enabled in the particular mgmt-server profile mapped to Airwave's IP
  • We can execute the below command to verify the profile
> show mgmt-server profile (insert profile name)
  • Make sure the below inline stats are enabled on the profile
Inline DHCP stats
Inline AP stats
Inline Auth stats
Inline DNS stats
On Airwave Side
  • Make sure Clarity and Amon is enabled under Amp Setup --> General page as shown in the below screen shot
Version history
Revision #:
2 of 2
Last update:
‎05-07-2016 03:10 PM
Updated by:
Labels (1)
