Monitoring, Management & Location Tracking
How to import Instant AP data in AMP from Activate server
How to import Instant AP whitelist data in AMP from Activate server
The Instant whitelist database is a list of the Instant APs that are allowed to access the AMP server after completing pre-shared key or certificate authentication.  AirWave AMP 8.0.9 allows network administrators to download Instant AP data from their Aruba Activate account directly into the Instant AP whitelist database.
To import Instant AP data from Activate to the AMP server:
1. Navigate to AMP Setup > General > Automatic Authorization.
2. In the Authorize Aruba Instant APs connecting to AirWave section, click Whitelist.
3. Next, navigate to Click Import Instant AP Whitelist from Activate. The Activate Settings page opens.
4. Configure the Activate settings to allow AirWave to access Instant AP data on the Activate server.
AirWave imports Instant AP data over a secure (HTTPS) connection. After AirWave receives the data from
Activate, a status message appears at the top of the Activate Settings window in AirWave, describing the
number of Instant APs added to or updated in the whitelist database, and the number of Instant APs removed
from the whitelist database.
Version history
Revision #:
2 of 2
Last update:
‎10-22-2015 08:36 AM
Updated by:
Labels (1)
