How to list all symbolic (soft) links
To get a list of all your symbolic links (also called symlinks or soft links) run the following command on the AMP command line:
# ll -R | grep ^l
The ll -R command lists all files recursively from the current directory. The second part of the command greps for the letter l as the first character in a line. A long listing of a symlink looks like this:
lrwxrwxrwx 1 root root 35 May 26 18:35 error_log -> /var/log/httpd/error_log.2010-05-26
If the directory tree contains a large number of symlinks, you can send the output to a file. For the /root directory, for example:
# cd
# ll -R | grep ^l > /tmp/symlink.txt
Version history
Revision #:
1 of 1
Last update:
‎06-17-2014 10:44 AM
Updated by:
