Monitoring, Management & Location Tracking
How to move space from one volume to other in Airwave(VM)
MVP
MVP
With Airwave deployed on VM it is critical to know the commands to move space from any logical volume to /. "/" is the volume primarily used for Airwave.
****Please collect the latest backup from the server before proceeding ****
Follow the steps below to accomplish this:
Execute the df -h command to find out the current logical volumes:
# df -h
Filesystem                                              Size  Used Avail Use% Mounted on
/dev/mapper/VolGroup-lv_root            50G   43G   7G  92% /
tmpfs                                                       127G     0  127G   0% /dev/shm
/dev/mapper/VolGroup-lv_home        242G  188M  230G   1% /home
/home has 242G, From /home we want to move 150G to / and at the same time reduce it to 20G
It is essential to unmount the logical volume to ensure no data loss occurs or data corruption:
  umount /home
The first step is to reduce the space to 20G and then mount that partition back:
  # e2fsck -f /dev/VolGroup/lv_home
  # resize2fs /dev/VolGroup/lv_home 20G
  # lvreduce -L 20G /dev/VolGroup/lv_home
  # mount /home
Finally extend the / partition by 150G to have a total of 200G:
  # lvextend -L 150G /dev/VolGroup/lv_root
  # resize2fs /dev/VolGroup/lv_root
Finally issue a reboot command to have the space applied:
# reboot
After reboot check the df -h command and it should show the space extended:
# df -h
/dev/mapper/VolGroup-lv_root        200G 43G 157G  11%  /
/dev/mapper/VolGroup-lv_home     92G   188M   80G   1% /home
T0 verify the logical volume see output of lvdisplay.
[root@testsyst ~]# lvdisplay
  --- Logical volume ---
  LV Path                /dev/VolGroup-lv_root
  LV Name                lv_root
  LV UUID                VzQzcz-NssK-8BIT-qtjz-XJho-0Mwd-fEbph1
  LV Write Access        read/write
  LV Creation host, time testsyst, 2014-05-01 23:51:39 +0530
  LV Status              available
  # open                 1
  LV Size                50.00 GiB
  Current LE             12800
  Segments               1
  Allocation             inherit
  Read ahead sectors     auto
  - currently set to     256
  Block device           253:3
  LV Path                /dev/VolGroup-lv_home
  LV Name                lv_home
  LV UUID                zNUKiG-QouE-q71z-ohNQ-0cFR-lggG-jNksZd
  LV Creation host, time testsyst, 2014-05-01 23:51:41 +0530
  LV Status              available
  # open                 1
  LV Size                245.50 GiB
  Current LE             62847
  Segments               1
  Allocation             inherit
  Block device           253:5
You can use the same command after moving the space to verify the contents are as required.
Version history
Revision #:
2 of 2
Last update:
‎03-18-2017 11:39 AM
Updated by:
Labels (1)
Contributors
