Challenge: How to prevent "ALE Meridian-tunnel" service from going down when the server is rebooted
Environment Information: ALE uses meridian-tunnel service to form a tunnel with the Meridian server on the cloud to send location data to Meridian.
Symptoms: If the meridan-tunnel service is down then Meridian will not receive the location data from ALE and that will impact showing the client locations in Meridian.
Cause: When the ALE server is rebooted the meridian-tunnel service will not start automatically and that makes ALE not to send location data to Meridian server.
Resolution: We must run the following command to start the meridian-tunnel service during every reboot until we add the meridian-tunnel service to the server check config list.
Instruction to add the meridian-tunnel service to service check config list:
Step 1.Run the following command to turn on check config for meridian-tunnel service.
# chkconfg meridian-tunnel on
Step 2:Run the following command to verify the check config and you will notice the service is set to ON for run level 2,3,4 and 5.
# chkconfig --list | grep -i meridian
Answer: Once the meridian-tunnel service is added to the service check config then if the server rebooted the meridian-tunnel service will be started by itself as show below.
