Monitoring, Management & Location Tracking
How to see the clients association history in 8.2.x ?
How to see the clients assosciation history in 8.2.x ?
From AMP 8.2.x version by using the default view we could see only 1 week of client association history as per design. In order to see the historical information we need to create a new view in Client detail -> Association history as shown below :
 1. navigate to Client detail -> Association history in AMP server.
 2. Select the drop down in association history and click on New view.
 3. Provide a name for the view, drag and drop the required association columns to the right side and click Ok. The new view will have association data older than 1 week.
Version history
Revision #:
2 of 2
Last update:
‎10-18-2016 03:30 PM
Updated by:
Labels (1)
