Monitoring, Management & Location Tracking
IOS APs require physical reboot after changes applied
This affects users who add ip access-lists to APs via Advanced IOS Config. Some older firmware versions, including 12.2(15)XR, get in a bad state when ip access-lists are copied to the running config. Versions XR2 and newer don't have the problem.
One solution is to upgrade the firmware first, then apply the changes.
Version history
Revision #:
1 of 1
Last update:
‎06-09-2014 03:44 PM
Updated by:
Labels (1)
Contributors
