IOS Firmware upgrade telnet EOF
Why do I see this in the log: "Telnet/SSH Error: pattern match read eof"?
Usually, that's an expected error. You'll see it any time that AMP issues a reboot command, because AMP's connection is terminated when the device goes offline.
If that's not it, it may be that the device is timing out while uploading a big file. On Cisco IOS devices, you can up the exec-timeout on the AP. The default is 5 minutes. On slow networks it can take well over 5 min just to download the file.
cisco1210-4.dev.airwa(config)#line vty 0 4
cisco1210-4.dev.(config-line)#exec-timeout 15
Also try increasing the AMP telnet timeout. measured in seconds
sub telnet_timeout { 10 }
in the /root/cvs/mercury/mercury/lib/perl/Mercury/AP/TelnetCLIBase.pm file.
After you've edited and saved that file, be sure to use the "ml" command to load your updated code.
Version history
Revision #:
1 of 1
Last update:
‎06-09-2014 09:21 AM
Updated by:
Labels (1)
Contributors
