Install Hangs on cciss
Problem: During the CentOS part of the installation it hangs on "cciss".
Solution: Add "acpi=off noapic" to the grub loader line.
This is fairly common on Compaq Proliant ML series servers.
Version history
Revision #:
1 of 1
Last update:
‎06-09-2014 03:35 PM
Updated by:
Labels (1)
