Monitoring, Management & Location Tracking
Intel's "Roaming Aggressiveness" selection for 4965agn/5000agn series NICs
The main two items that are used for roaming is AP RSSI and Missed Beacons.
About the driver setting “Roaming Aggressiveness” parameter --- The -dBm value when the NIC will start to look for a better AP based on their driver's "Roaming Aggressiveness" selection in the driver settings. Assuming we are talking about their 11n NICs since that is what we are focusing on.
For 2.4 GHz
- Medium = -72 (default)
- Medium High = -67
- Highest = -62
For 5 GHz
- Medium = -75 (default)
- Medium High = -70
- Highest = -65
Version history
Revision #:
1 of 1
Last update:
‎06-17-2014 09:29 AM
Updated by:
Labels (1)
