Master Console DNS Resolution for AMPs
If you prefer to add an associated AMP in the Master Console using just the AMP's DNS hostname, instead of the AMP's fully-qualified domain name (FDQN), you can edit the Master Console's '/etc/resolv.conf' file via a TELNET or SSH secession to add DNS search domains:
search my.domain.com
search your.domain.com
search his.domain.net
search her.personal.domain.org
Once you've added these search entries to the top of the '/etc/resolv.conf' file, the Master Console will append each listed domain, in the order it's listed in the file, whenever you use only a hostname at the Master Console's web GUI or at the CLI. Note that you must list the domain for every AMP associated with the Master Console; otherwise, if an AMPs domain is not listed in '/etc/resolv.conf', you will need to use the AMPs FQDN in the Master Console's Web GUI and in its CLI.
Version history
Revision #:
1 of 1
Last update:
‎06-06-2014 04:05 PM
Updated by:
Labels (1)
Contributors
