Monitoring, Management & Location Tracking
Master WDS setup for device and rogue discovery using local radius server
Setting up a Cisco AP to be a WDS Master
The following config can be cut and pasted directly into your Telnet/SSH session to configure a Cisco AP running 12.3(7)JA1 (or 12.2(13)JA4) as a WDS master. Change the priority level to from 255 to 254 to make a backup WDS server. The !s in the document are comments in Cisco IOS, so it is possible to cut and past all the lines below into a Telnet/SSH session to configure the AP without having to manually type all the lines below.
! This next line enables the AAA settings
aaa new-model
!The next couple of lines sets up the local RADIUS server. User=wdsuser password=wdspassword
radius-server local
user wdsuser password 0 wdspassword
! The wdssecret on the next line is the shared RADIUS secret
nas 192.168.10.63 key 0 wdssecret
exit
! This next line sets up the radius AAA client on the AP. wdssecret is the shared secret
radius-server host 192.168.10.63 auth-port 1812 acct-port 1813 key 0 wdssecret
! This sets this AP up as the WDS Master
wlccp wds priority 255 interface BVI 1
! This next line sets up what group WDS should use for authentication
wlccp authentication-server infrastructure method_WDS
! This set of lines configures the WDS authentication profile
aaa group server radius WDS
server 192.168.10.63 auth-port 1812 acct-port 1813
exit
aaa authentication login method_WDS group WDS
! This line enables the AP radio(s) to act as a WDS client (this is the line thatll be on all the other client APs)
! username=wdsuser and password=wdspassword
wlccp ap username wdsuser password wdspassword
! This line sets up the WLSE as a destination point to send the rogue and other WDS info to WLSE
wlccp wnm ip address 5.1.4.99
aaa new-model
radius-server local
exit
exit
Version history
Revision #:
1 of 1
Last update:
‎06-09-2014 08:57 AM
Updated by:
Labels (1)
Contributors
