Migrating Airwave to new HPE servers
MVP
MVP
Migration of existing AMP to new HPE servers.
- Existing AMP servers or VM infrastructure.
- New HPE AMP server
All new HPE AMP servers which will be shipped will be pre loaded with AMP version 8.2.0.2
Scenario 1:
Existing server or VM server with any version prior to 8.2.0.2, should be upgraded to 8.2.0.2 version by
# start_amp_upgrade -v 8.2.0.2
Take backup of existing server by below command. The backup will be stored under /alternative folder as databackup.tar.gz
# amp_backup
Restore the backup on new HW by copying the backup file under /tmp location
# amp_restore -d /tmp/datbacakup.tar.gz
Scenario 2:
Existing AMP server or VM server with version greater than 8.2.0.2, new HPE server should be upgraded to same version as existing server by
# start_amp_upgrade -v <Existing AMP version>
# amp_backup
1. Always make sure, we run the commands from /root/svn/mercury/ folder on AMP CLI.
2. Please use 'Screen' mode on CLI to ensure upgrades, restore or backups will run smoothly even if CLI times out or closed by mistake
# screen
Below link will explain the usage of screen mode in Linux terminals.
http://www.tecmint.com/screen-command-examples-to-manage-linux-terminals/
https://www.rackaid.com/blog/linux-screen-tutorial-and-how-to/
3. If AMP server cannot reach internet for online upgrades, please copy the upgrade image to /root folder and run the upgrade commands from /root/svn/mercury directory.
1. To ensure upgrade is completed, please check the upgrade log under /var/log/upgrade directory.
2. to ensure, backup restore is completed, verify the restore log under /var/log directory
3. Always check mdf5sum of the upgrade image or backup taken to ensure the files are intact. to check md5sum in aMP, run
# md5sum <file name>
ex: # md5sum databackaup.tar.gz
4. Once the migration is done, make sure to login to UI and verify if the AP count is fine and VisualRF working fine
Version history
Revision #:
2 of 2
Last update:
‎05-05-2016 01:09 PM
Updated by:
Labels (1)
Contributors
