More than one template matching device
There are three options: create a separate template for each version of firmware running on one of their APs; upgrade the firmware on the APs so that all (or more) of the APs are running the same firmware; don't specify a firmware version in the template form.
Version history
Revision #:
1 of 1
Last update:
‎06-09-2014 09:27 AM
Updated by:
Labels (1)
Contributors
