.NET installed after Excel and Visio AWSP
Note - AWSP only support .NET 1.1
The error says "could not find .NETcomponents . . ."
This is a symptom that the .NET Framework which AWSP requires is not not enabled. It's often disabled because the option was not enabled during install or because Office has been upgraded from older versions which did not include .NET. Here's how to enable .NET:
- Go to Start->Control Panel->Add or Remove Programs -> Microsoft Office Professional click on Change-> Add or Remove Features
- Select the "Choose advanced customization of applications" and click update.
- Under Excel select the .NET framework related items and choose run from computer. If this a .NET under office shared features or Office Tools you should select those as well.
Next, repeat the same process with Visio.
If you are still having problems, try uninstalling AWSP and reinstalling.
Version history
Revision #:
1 of 1
Last update:
‎06-10-2014 03:18 PM
Updated by:
Labels (1)
Contributors
