Not able to login to Airwave GUI
MVP
MVP
Problem:
Not able to login to the Airwave web interface. User/password not accepted
Diagnostics:
We would be seeing the below error message in the httpd error log, when we try to login to the server.
DBD::Pg::st execute failed: ERROR:  database is not accepting commands to avoid wraparound data loss in database "airwave"
HINT:  Stop the postmaster and use a standalone backend to vacuum that database.
You might also need to commit or roll back old prepared transactions. at /usr/local/airwave/lib/perl/Mercury/DB/Q/st.pm line 20.
[Fri May 06 15:00:03 2016] [error] [client 127.0.0.1] DBD::Pg::st execute failed: ERROR:  database is not accepting commands to avoid wraparound data loss in database "airwave"\nHINT:  Stop the postmaster and use a standalone backend to vacuum that database.\nYou might also need to commit or roll back old prepared transactions. at /usr/local/airwave/lib/perl/Mercury/DB/Q/st.pm line 20.\n\t(in cleanup) DBD::Pg::st execute failed: ERROR:  database is not accepting commands to avoid wraparound data loss in database "airwave"\nHINT:  Stop the postmaster and use a standalone backend to vacuum that database.\nYou might also need to commit or roll back old prepared transactions. at /usr/local/airwave/lib/perl/Mercury/DB/Q/st.pm line 20.\n, referer: https://airwave.ca.com/site_list
If for some reason autovacuum fails to clear old XIDs from a table, the system will begin to emit warning messages like this when the database's oldest XIDs reach ten million transactions from the wraparound point
WARNING:  database "airwave" must be vacuumed within 177009986 transactions
HINT:  To avoid a database shutdown, execute a database-wide VACUUM in "airwave".
A manual VACUUM should fix the problem, as suggested by the hint; but note that the VACUUM must be performed by a superuser, else it will fail to process system catalogs and thus not be able to advance the database's datfrozenxid.) If these warnings are ignored, the system will shut down and refuse to start any new transactions once there are fewer than 1 million transactions left until wraparound:
HINT:  Stop the postmaster and use a standalone backend to VACUUM in "airwave".
Solution
When we fall to this scenario, we have to enter the single-user backend for airwave. Below are the steps we need to follow to fix this issue,
# amp_disable
# service postgresql stop
Now enter the single-user backend for "airwave"
# su postgres -c "postgres --single -D /var/lib/pgsql/9.2/data airwave"
PostgreSQL stand-alone backend 9.2.4
Do a full vacuum analyze
backend> vacuum Full analyze;
Do ctl+D to exit the backend shell
#service postgresql start
# amp_enable -now
Once analyze is done it will come back
Version history
Revision #:
2 of 2
Last update:
‎05-07-2016 03:05 PM
Updated by:
Labels (1)
Contributors
