Monitoring, Management & Location Tracking
Orange flashing LED on Airwave hardware with device fan error
Question : I am seeing flashing orange light on the AirWave appliance and see a fan error while booting the server.
Environment Information : This applies to all versions of Airwave.
Symptoms : Flashing orange LED would be seen on the hardware.
Cause: This issue is caused because of the fan failure of the Server.
Resolution : The below error would be seen on the console of the Airwave server while it's booting.
User-added image
Following are the options to resolve the issue
Option 1: If it is an AirWave appliance ( hardware shipped by Aruba) please create a ticket Aruba TAC and we will RMA the box, if the support contract is valid.
Option 2:
If it is a third party server ( purchased directly from Vendor like Dell or IBM), please get in touch with them to replace the faulty part/server.
Version history
Revision #:
1 of 1
Last update:
‎07-11-2014 09:24 AM
Updated by:
Labels (1)
Contributors
