PAPI process in Airwave continuously bootstraps
MVP
MVP
Problem:
In the recent Airwave upgrades we are randomly noticing that the PAPI process never be stable and bootstraps PAPI process continuously.
This behavior impacts the following feature:
> Clients count and usage graph doesn't update.
> App RF data will not get updated.
Diagnostics:
The PAPI process starts to fail when Airwave couldn't resolve the server's hostname hence it log the following error message in service watcher log and tries to bootstrap the papi process.
Solution
We can resolve this issue by adding a manual entry in /etc/hosts file as shown below.
Syntax to add DNS entry into Airwave:
echo -e "amp eth0 IP"'\t'"FQDN"'\t'"hostname" >> /etc/hosts
Current /etc/hosts:
[root@current_amp mercury]# cat /etc/hosts
127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4
::1         localhost localhost.localdomain localhost6 localhost6.localdomain6
Hostname/FQDN of Airwave:
[root@current_amp mercury]# hostname
current_amp.nslab.com
Adding host entry into /etc/hosts:
[root@current_amp mercury]# echo -e "10.29.161.57"'\t'"current_amp.nslab.com"'\t'"current_amp" >> /etc/hosts
Updated entry:
10.29.161.57    current_amp.nslab.com   current_amp
Restart the services:
[root@current_amp mercury]# rd
Once the service is restarted the PAPI service will be stable and graphs will be updated.
Version history
Revision #:
2 of 2
Last update:
‎12-28-2016 06:53 AM
Updated by:
Labels (1)
Contributors
