Monitoring, Management & Location Tracking
last person joined: one year ago
Articles relating to existing and legacy HPE Aruba Networking products and solutions including AirWave, Meridian Apps, ALE, Central / HPE Aruba Networking Central, and UXI / HPE Aruba Networking User Experience Insight
Package Errors while installing VIA on Linux Cent OS clients
Jun 29, 2014 05:16 PM
Does packagekit errors on Linux CentOS caused due to VIA software?
Users might encounter errors related to Packagekit while installing VIA on the Linux CentOS clients; does it really issue due to VIA software?
Below is the explanation;
What is PackageKit?
         Helps in installing and updating software. This component is also responsible for checking OS updates. Some users think it is annoying as it automatically displays a updates available dialog on every login.
How to check if PackageKit is installed?
                   From a window, double click on a rpm  file, if the PackageKit is installed , then it will take over the control and tries to install the rpm.
How to restore the PackageKit if not installed or Uninstalled?
                Ensure the system is connected to network and run the following commands in sequence.
“sudo yum update”
“sudo yum install PakageKit”
“sudo yum install gnome-packagekit”
“sudo reboot now”
The packetkit issue is not really related to VIA functionality; it is about a dependency module that is either not present or corrupted in the user system.
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
Related Entries and Links
No Related Resource entered.
