Patch to fix Help files in AirWave 7.6.4
In AirWave 7.6.4, the help files are broken. This article has a patch that fixes that and instruction for applying that fix.
1. Save the attached file, amp-DE14868_patch.tgz in the /var/airwave/custom directory of your AirWave server.
2. Run these commands:
cd /root/svn/mercury
tar -xvzf /var/airwave/custom/amp-DE14868_patch.tgz
make install_docroot_files
Version history
Revision #:
1 of 1
Last update:
‎07-03-2014 07:39 PM
Updated by:
Labels (1)
Contributors
