Problem Upgrading AMP
Q: I just tried to upgrade AMP and I think there were problems. How can I tell?
A: AMP creates an upgrade log in the /tmp directory each time an upgrade is performed. Example:
/tmp/AMP-4.3.0-upgrade.log
If you're familiar with the vi text editor you could open it in vi, or you could tail the log to see the last several lines, like this:
# tail /tmp/AMP-4.3.0-upgrade.log
Version history
Revision #:
1 of 1
Last update:
‎06-09-2014 09:08 AM
Updated by:
Labels (1)
Contributors
