Red Hat 4 Support (RHEL4):-
Version 6.2 is the last version to support Red Hat Enterprise 4 and CentOS 4. As of version 6.3, AWMS no longer supports Red Hat Enterprise 4, or CentOS 4. If you are running CentOS, directions to upgrade your OS are included in the article titled "AirWave CentOS 4 to 5.3 Upgrade Using_AMP 6.3 ISO" (http://kb.airwave.com/?sid=50140000000MjFE).
Version history
Revision #:
1 of 1
Last update:
‎06-24-2014 02:44 PM
Updated by:
Labels (1)
Contributors
