Monitoring, Management & Location Tracking
Reports: Keeping a definition, removing the scheduling :-
Are your reports taking too long to run? Has another AirWave user been creating reports and scheduling them to run daily? Although only Admins can see the reports and report definitions of these users, you can still delete the scheduling if you have access to the command line:
# db
# \x
# select * from scheduled_event;
# delete from scheduled_event where id in (##,##,##,##,##,##);
# \q
If you want to isolate out the admin user reports, here's a query to get you all reports that are not made by the admin:
# select * from report_definition where role_id != #;
To check user roles:
# select username, role_id from users;
Deleting the scheduling will still leave the report definition in the definitions listing.
Version history
Revision #:
1 of 1
Last update:
‎06-24-2014 03:07 PM
Updated by:
Labels (1)
Contributors
