Reset VisualRF in AirWave 8.0.x.x version
Introduction- If the VisualRF data has become corrupted and VisualRF will not run, here are the steps to reset it:
Environment- The steps given below have been tested and validated for AirWave 8.0.x.x versions.
Answer-
  • Login to the CLI of AMP via SSH.
  • Navigate to mercury directory.
                    #cd /root/svn/mercury
  • Disable the AMP.
                    #amp_disable
  • Disable VisualRF.
                    #dbc "update seas_config set visualrf_enabled = 0;"
  • Bootstrap VisualRF.
                    #bootstrap_vrf_db
                    #bootstrap_vrf_redis
  • Enable AMP.
                    #rm –rf /etc/amp_disabled
  • Enable VisualRF.
                    #dbc "update seas_config set visualrf_enabled = 1;"
Now the VisualRF has been reset, login to the GUI of AMP to confirm the same.
Verification- After running the above steps, login to the GUI of AMP to find VisualRF module reset to factory settings.
Version history
Revision #:
1 of 1
Last update:
‎04-05-2015 02:37 AM
Updated by:
Labels (1)
Contributors
