Q: How to restart Airwave Visualrf from CLI
A:
We can execute the below command to restart Visualrf from Airwave CLI,
# psk airwave.visualrf
Its suggested to remove VisualRF cache before restarting VisualRF
# rm /var/airwave/cache/visualrf_bootstrap
To verify the services are up, we can use the below commands,
# tll service watcher
in above command you would see below output when Visualrf service is completely up and visible
Thu May 5 23:03:30 2016: restarting VisualRF Engine...
HTTP server is listening on port 6654
Web services started for visualrf/ws/LocationApi
# top -c
Using the above command we can see the status on visualrf process
We can tail visualRf log as well by below command and see VisualRF startup.
# tail -f /var/log/visualrf.log
