SNMP Set Error
Q: I have devices that are Up in the AMP, but when I try to configure them, I get an error like: "Error (SNMP Set Error: Received commitFailed(14) error-status at error-index 1)". What can the problem be?
A: Usually you'd see this if AMP is monitoring the device with a read-only community string. This error indicates that we can't write changes to the device with the credential we're using.
Q: How can I troubleshoot it?
A: A good test would be to change something trivial, like the sysContact. I'll describe it below using s2w and s2s, which are AMP's built-in shortcuts for snmpwalk and snmpset with SNMP v2c.
First, verify that you can read the sysContact:
# s2w 10.51.3.199 private sysContact
SNMPv2-MIB::sysContact.0 = STRING: joemontana
OK, so we can read that the sysContact is joemontana. Now we'll try to change it:
# s2s 10.51.3.199 private sysContact.0 s williemays
SNMPv2-MIB::sysContact.0 = STRING: williemays
So that worked. I successfully changed the contact to williemays
If I tried to do that with a read-only string, I'd get an error:
# s2s 10.51.3.199 public sysContact.0 s sleepyfloyd
Error in packet.
Reason: noAccess
Failed object: SNMPv2-MIB::sysContact.0
Error in packet.
Reason: noAccess
Error in packet.
Reason: noAccess
Version history
Revision #:
1 of 1
Last update:
‎06-09-2014 09:21 AM
Updated by:
Labels (2)
Contributors
