Sample XML for VisualRF Batch Upload
This xml works in AirWave 7.0 (and very likely newer and older versions):
<?xml version="1.0" encoding="ISO-8859-1" ?>
<visualrf:site_batch xmlns:visualrf="http://www.airwave.com" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1" origin="lower-left">
<floor name="Downtown Gotham Floor 1" number="1" building-name="Gotham" campus-name="STORES">
<image filename="DTGotham_1.dwg" />
<access-points>
<access-point name="Gotham_1_AP-125_1" x="303.1" y="137.09">
<radio phy="G" beamwidth="360" orientation="0" gain="2.2" mount="G" />
<radio phy="A" beamwidth="360" orientation="0" gain="3.5" mount="G" />
</access-point>
<access-point name="Gotham_1_AP-125_2" x="211.43" y="283.35">
</access-point>
</access-points>
<walls>
<wall type="2" x1="299.61" y1="256.47" x2="299.61" y2="235.14" />
<wall type="2" x1="300.03" y1="256.89" x2="283.33" y2="256.89" />
</walls>
</floor>
<floor name="Downtown Gotham Floor 2" number="2" building-name="Gotham" campus-name="STORES">
<image filename="DTGotham_2.dwg" />
<access-points>
<access-point name="Gotham_2_AP-125_1" x="303.1" y="137.09">
</access-point>
<access-point name="Gotham_2_AP-125_2" x="211.43" y="283.35">
</access-point>
</access-points>
<walls>
</walls>
</floor>
</visualrf:site_batch>
Version history
Revision #:
3 of 3
Last update:
‎07-01-2014 04:49 PM
Updated by:
Labels (1)
