Setup Clarity with IAP on Airwave
MVP
MVP
Instant AP support clarity starting version  6.5.1.0-4.3.1.0.
Prerequisites
IAP running version  6.5.1.0-4.3.1.0 or above.
Airwave running version 8.2.3.1 or above
We will need to enable Clarity function on IAP. This can be done via Airwave or directly on IAP.
From IAP CLI:
18:64:72:c9:c4:98# configure terminal
We now support CLI commit model, please type "commit apply" for configuration to take effect.
18:64:72:c9:c4:98 (config) # clarity
18:64:72:c9:c4:98 (clarity) #
18:64:72:c9:c4:98 (clarity) #  inline-auth-stats
18:64:72:c9:c4:98 (clarity) #  inline-dhcp-stats
18:64:72:c9:c4:98 (clarity) #  inline-dns-stats
18:64:72:c9:c4:98 (clarity) #  inline-sta-stats
18:64:72:c9:c4:98 (clarity) # end
18:64:72:c9:c4:98# commit apply
committing configuration...
configuration committed.
From IAP WEBUI
From Airwave Template :
Add the below config lines towards the end of the template.
clarity
 inline-sta-stats
 inline-auth-stats
 inline-dhcp-stats
 inline-dns-stats
After adding the config, we will be able to see the Clarity data populating on Airwave.
Version history
Revision #:
2 of 2
Last update:
‎03-18-2017 12:42 PM
Updated by:
Labels (1)
Contributors
