Monitoring, Management & Location Tracking
Support Connection fails with "FATAL: Could not load /lib/modules/2.6.18-xxx/modules.dep: No such file or directory
If "service support_connection start" fails with the following error message or similar:
FATAL: Could not load /lib/modules/2.6.18-194.32.1.el5/modules.dep: No such file or directory
This usually indicates that a kernel upgrade has been performed but the required server reboot has not happened yet.
You can verify the current RUNNING kernel with "uname -a"
[root@garrison modules]# uname -a
Linux 2.6.18-274.7.1.el5 #1 SMP Thu Oct 20 16:21:01 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
If you do an ls -l of the /lib/modules you should entries for the current kernel and possibly for older kernels.
[root@garrison modules]# ls -l /lib/modules/
total 12
drwxr-xr-x 3 root root 4096 Oct 24 06:18 2.6.18-238.12.1.el5/
drwxr-xr-x 6 root root 4096 Nov 21 15:36 2.6.18-274.7.1.el5/
You can check the current INSTALLED kernel via "rpm -qa kernel"
[root@garrison modules]# rpm -qa kernel
if the current RUNNING kernel from "uname -a" doesn't match the INSTALLED kernel "rpm -qa kernel" and you can see that the FATAL error is referencing an older or missing kernel modules.dep then a reboot will probably resolve the issue.
Version history
Revision #:
1 of 1
Last update:
‎06-29-2014 09:12 AM
Updated by:
Labels (1)
