Supported Cisco WLC Traps :-
The following traps are what we parse and summarize in the alert summary widget. All the other traps are parsed and logged in the event log.
ciscoLwappAAARadiusReqTimedOut - 'SNMPv2-SMI::enterprises.9.9.598.0.5' => ['handle_radius_timeout_trap'],
bsnDot11StationBlacklisted - 'SNMPv2-SMI::enterprises.14179.2.6.3.52' => ['handle_blacklist_trap'],
bsnSignatureAttackDetected - 'SNMPv2-SMI::enterprises.14179.2.6.3.70' => ['handle_ids_trap', 'ids_trap'],
bsnAuthenticationFailure - 'SNMPv2-SMI::enterprises.14179.2.6.3.27' => ['handle_auth_failure_trap'],
bsnRADIUSServerNotResponding - 'SNMPv2-SMI::enterprises.14179.2.6.3.26' => ['handle_radius_noresponse_trap'],
bsnAPDisassociated - 'SNMPv2-SMI::enterprises.14179.2.6.3.8' => ['handle_ap_disassociation_trap'],
bsnAPAssociated - 'SNMPv2-SMI::enterprises.14179.2.6.3.7' => ['handle_ap_association_trap'],
bsnDot11StationAssociate - 'SNMPv2-SMI::enterprises.14179.2.6.3.53' => ['handle_client_trap', 'association'],
bsnDot11StationDisassociate - 'SNMPv2-SMI::enterprises.14179.2.6.3.1' => ['handle_client_trap', 'disassociation'],
bsnDot11StationDeauthenticate - 'SNMPv2-SMI::enterprises.14179.2.6.3.2' => ['handle_client_trap', 'deauthenticate'],
ciscoLwappDot11ClientMovedToRunState - 'SNMPv2-SMI::enterprises.9.9.599.0.4' => ['handle_client_trap', 'authentication'],
Version history
Revision #:
1 of 1
Last update:
‎06-25-2014 03:50 PM
Updated by:
Labels (1)
Contributors
