Monitoring, Management & Location Tracking
The Rogue count on the top header for admin and read-only user is different
Environment Information- This applies to Airwave versions 8.0.x and prior.
Symptoms- If i login to Airwave as an Admin user, i see "x" rogues displayed on the top header while when I login as Read-only-user, the count is different.
The first capture is taken when user is logged in as Administrator.
The second capture is taken when user logged in as a read only user.
Cause- This does not depends on the roles or access levels. This depends on the filetr level applied for rogues under Home- User Info tab.
Resolution- The top header rogue count is calculated based on the above configuration. If we set the filter as "Suspected Rogue", the total count will be the summary of  devices classified as "suspected rogue" and "rogue".
Similarly if we have set the filter as valid, the header will show summary of device classified as per below list.
Version history
Revision #:
1 of 1
Last update:
‎04-03-2015 12:16 AM
Updated by:
Labels (1)
