To create AMP Public Portal from Master Console
We can create a public folder for individual AMP's from Master Console to check the user and bandwidth graphs.
Here are 3 simple steps to do so:
1. Navigate to AMP Setup>General page on Master Console and set the Public Portal to ‘yes’ and ‘Save and Apply’
2. Then you will see a new tab ’Portal’ in the header column, once you click on that add a note to your header and footer as you wish and ‘save’.
3. Then click on Launch portal to launch the public site or you can always navigate to https://<Ampname or AMP FQDN>/public/ to get to the site and you will see folder for each managed AMP, click on the folder to see its user and bandwidth graphs.
Attached is pdf format with screenshots.
Version history
Revision #:
1 of 1
Last update:
‎06-26-2014 05:15 PM
Labels (1)
