Monitoring, Management & Location Tracking
Troubleshooting Aruba Instant AP Connectivity (swarm debug)
1. Check the pound log. pound is a proxy server that intercepts all swarm communication and hands it off out our SwarmHandler (all non-swarm traffic goes to apache). This would be a good command:
# grep swarm /var/log/pound
If there are no results for that command, it means that no requests are arriving from the Instant APs.
2. Enable the qlog topic called swarm_debug
# qlog enable swarm_debug
That creates a swarm_debug log in /var/log/amp_diag that's base64-encoded. You could use this command after enabling the logging to see detailed headers that actually arrive at the AMP:
# qlog_decoder --topics <topic> --notail --nofollow /var/log/amp_diag/swarm_debug
Valid topics include:
cmd_queue (records all commands sent to SwarmHandler)
headers (HTTPS headers received from a swarm)
commands (when a command is being put into HTTPS response)
config (the running-config sent from a swarm)
delta-config (the delta-config being sent to SwarmHandler)
state (decoded state payload data)
stat (decoded stat payload data)
This command is useful for putting human-readable versions of each topic into /tmp/swarm:
# mkdir -p /tmp/swarm; for x in cmd_queue headers commands config delta-config state stat; do qlog_decoder --topics $x --notail --nofollow /var/log/amp_diag/swarm_debug > /tmp/swarm/$x; done
3. On the IAP, from the support link, you can check the device's Datapath Session Table for connections to AMP by the virtual controller.
Version history
Revision #:
1 of 1
Last update:
‎06-26-2014 09:09 AM
Updated by:
Labels (1)
Contributors
