Monitoring, Management & Location Tracking
Troubleshooting while getting certificate error while accessing VisualRF in AMP 8.2.0
MVP
MVP
Problem:
While accessing Visual RF you are getting the error as below:
Seeing the below errors in VisualRF log
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
        at sun.security.ssl.Alerts.getSSLException(Unknown Source)
        at sun.security.ssl.SSLSocketImpl.fatal(Unknown Source)
        at sun.security.ssl.Handshaker.fatalSE(Unknown Source)
        at sun.security.ssl.ClientHandshaker.serverCertificate(Unknown Source)
        at sun.security.ssl.ClientHandshaker.processMessage(Unknown Source)
        at sun.security.ssl.Handshaker.processLoop(Unknown Source)
        at sun.security.ssl.Handshaker.process_record(Unknown Source)
        at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)
Diagnostics:
This is more likely to be seen if the Custom Cert installed to the Airwave server and the CA is not automatically updated to the trusted list in Java Keystore. In that case the mentioned error could occur with the visualrf app (run on Java) to trust the CA.  Hence, you need to make the Certificate is trusted in keystore of java in /usr/java/jre1.8.0_72/lib/security/cacerts.
Solution
To solve this issue you need to make sure the CA cert is trusted in the Keystore of java under  /usr/java/jre1.8.0_72/lib/security/cacerts.
To do that you need to execute the commands below:
# keytool -import -noprompt -trustcacerts -alias <give a name to identify the CA in the keytool> -file <path/of the /cert/in/airwave/server> -keystore /usr/java/jre1.8.0_72/lib/security/cacerts -storepass changeit
Example:
[root@airwave tmp]# keytool -import -noprompt -trustcacerts -alias chaincert-lab -file /var/airwave/custom/ssl-certs/airwave-CertChain.crt -keystore /usr/java/jre1.8.0_72/lib/security/cacerts -storepass changeit
Certificate was added to keystore
To verify:
[root@airwave tmp]# keytool -list -keystore "/usr/java/jre1.8.0_72/lib/security/cacerts" | grep chain
Enter keystore password:  changeit
chaincert-lab, May 2, 2016, trustedCertEntry,
Once done, restart the Visual RF Engine.
Version history
Revision #:
2 of 2
Last update:
‎10-25-2016 03:33 PM
Updated by:
Labels (1)
Contributors
