If you are upgrading according to any of these paths:6.2rc4 beta --> 6.2 General beta6.2 General beta --> 6.2 general release6.2rc4 beta --> 6.2 general releaseYour upgrade may fail with this message:/root/AMP-6.2.0_beta4-amp_upgrade: line 3: syntax error near unexpected token `newline'/root/AMP-6.2.0_beta4-amp_upgrade: line 3: ` <head>'There is a typo in the upgrade script that generates an incorrect file path. To apply the fix:1. Ssh into your AMP server as root2. Enter the scripts directory# scripts3. Within the scripts directory, there is a script called start_amp_upgrade. This file contains a one-letter typo that must be fixed using VI or another text editor. If you're unfamiliar with editing files in Linux, contact support@airwave.com for assistance.The typo is on line 110:$TARGET_fILEshould be$TARGET_FILE**note the change between lowercase "f" and capital "F"After saving the file run ml from the AMP command line. When the make is done, run the upgrade command again:# start_amp_upgrade -v 6.2.0_beta3If you are upgrading according to any of these paths:6.2rc4 beta --> 6.2 General beta6.2 General beta --> 6.2 general release6.2rc4 beta --> 6.2 general releaseYour upgrade may fail with this message:/root/AMP-6.2.0_beta4-amp_upgrade: line 3: syntax error near unexpected token `newline'/root/AMP-6.2.0_beta4-amp_upgrade: line 3: ` <head>'There is a typo in the upgrade script that generates an incorrect file path. To apply the fix:1. Ssh into your AMP server as root2. Enter the scripts directory# scripts3. Within the scripts directory, there is a script called start_amp_upgrade. This file contains a one-letter typo that must be fixed using VI or another text editor. If you're unfamiliar with editing files in Linux, contact support@airwave.com for assistance.The typo is on line 110:$TARGET_fILEshould be$TARGET_FILE**note the change between lowercase "f" and capital "F"After saving the file run ml from the AMP command line. When the make is done, run the upgrade command again:# start_amp_upgrade -v 6.2.0_beta3If you are upgrading according to any of these paths:6.2rc4 beta --> 6.2 General beta6.2 General beta --> 6.2 general release6.2rc4 beta --> 6.2 general releaseYour upgrade may fail with this message:/root/AMP-6.2.0_beta4-amp_upgrade: line 3: syntax error near unexpected token `newline'/root/AMP-6.2.0_beta4-amp_upgrade: line 3: ` <head>'There is a typo in the upgrade script that generates an incorrect file path. To apply the fix:1. Ssh into your AMP server as root2. Enter the scripts directory# scripts3. Within the scripts directory, there is a script called start_amp_upgrade. This file contains a one-letter typo that must be fixed using VI or another text editor. If you're unfamiliar with editing files in Linux, contact support@airwave.com for assistance.The typo is on line 110:$TARGET_fILEshould be$TARGET_FILE**note the change between lowercase "f" and capital "F"After saving the file run ml from the AMP command line. When the make is done, run the upgrade command again:# start_amp_upgrade -v 6.2.0_beta3
