Monitoring, Management & Location Tracking
Unable to set enable Admission Control on Airespace controller
In order to enable Admission Control (aka ACM, or CAC) each WLAN for that controller must have WMM disabled. If you're unable to enable Admission Control, check each of that Group's WLANs and make sure that WMM is disabled.
Version history
Revision #:
1 of 1
Last update:
‎06-09-2014 09:35 AM
Updated by:
Labels (1)
