Monitoring, Management & Location Tracking
last person joined: one year ago
Articles relating to existing and legacy HPE Aruba Networking products and solutions including AirWave, Meridian Apps, ALE, Central / HPE Aruba Networking Central, and UXI / HPE Aruba Networking User Experience Insight
Updating AMP To Recognize Changes in Daylight Saving Time
Jun 09, 2014 01:02 PM
Probably the easiest way to update your AMP to deal with daylight saving time changes is to refresh the TZDATA file and install a couple of RedHat date and time configuration packages. To accomplish this task, enter the following at the AMP command line:
yum -y install tzdata system-config-date redhat-config-date
setup
The 'setup' command will take you to the RedHat command-line configuration tool. From there, use your arrow keys to move the cursor to 'Time zone configuration' and type 'Enter' to select the option. Next, select the appropriate timezone for the location of your AMP in the following screen. Use the 'tab' key to navigate to the option for 'System clock uses UTC'. If your system clock is set to GMT/UTC, select this option using the 'spacebar'. Otherwise, you can leave unselected. Finally, type 'tab' again to center the cursor over the 'OK', type 'Enter' again, then hit 'tab' twice and exit with 'Enter'. Your AMP should now have updated timezone files.
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
Related Entries and Links
No Related Resource entered.
