Monitoring, Management & Location Tracking
Usage data is not shown/populated on Airwave when a new controller is added?
MVP
MVP
Q:
Why usage Graph data is not shown/populated on Airwave when a new controller is added?
A:
When a controller and its APs are added to Airwave in monitor only mode to a groups which is set to not audit the device [Group>>Basic>>Config audit set to No] then Airwave would receive the stats data of network clients and client's usage however since the configuration is not audited/read from the controller it would not be able to map the client usage data to the respective APs bssid, hence the usage graph will be blank.
When the controller is audited once then the graph data for usage will be populated and updated.
Version history
Revision #:
2 of 2
Last update:
‎10-30-2015 10:05 AM
Updated by:
Labels (1)
Contributors
