Use of uninitialized value in numeric lt (<) at /usr/local/airwave/lib/perl/Mercury/Reports/PickledRowsFromRRDs.pm line 59, <RRDOUT> line 13566.
The following error is experienced in 6.3.0 and 6.3.1:
"Use of uninitialized value in numeric lt (<) at /usr/local/airwave/lib/perl/Mercury/Reports/PickledRowsFromRRDs.pm line 59, <RRDOUT> line 13566."
If you see this error, the solution is to upgrade to 6.3.2.
Version history
Revision #:
1 of 1
Last update:
‎06-10-2014 08:16 PM
Updated by:
Labels (1)
Contributors
