-- SYMPTOM -- AMP is stuck in nightly maintenance mode. The log file (/var/cron_stopped_maintenance) shows a error such as the following: DBI connect('dbname=airwave','airwave',...) failed: FATAL: database is not accepting comm ands to avoid wraparound data loss in database "postgres" HINT: Stop the postmaster and use a standalone backend to vacuum database "postgres". at /usr/local/airwave/lib/perl/Mercury/Utility/SQL.pm line 90 at /usr/local/airwave/lib/perl/Mercury/Utility/SQL.pm line 97 Mercury::Utility::SQL::get_new_dbh('Mercury::Utility::SQL', 'undef', 'undef', 'und ef') called at /usr/local/airwave/lib/perl/Mercury/Utility/SQL.pm line 75 Mercury::Utility::SQL::connect_to_db('Mercury::Utility::SQL') called at /usr/local /airwave/lib/perl/Mercury/DB/Q.pm line 20 Mercury::DB::Q::init('Mercury::DB::Q=HASH(0x8593a88)') called at /usr/local/airwav e/lib/perl/Mercury/Base.pm line 46 Mercury::Base::new_from_hashref('Mercury::DB::Q', 'Mercury::DB::Q=HASH(0x8593a88)' ) called at /usr/local/airwave/lib/perl/Mercury/Base.pm line 21 Mercury::Base::new('Mercury::DB::Q') called at /usr/local/airwave/bin/vacuum_amp l ine 28 ------------- -- SOLUTION -- 1. Disable AMP # disable_amp 2. Make sure postgres service is stopped # service postgresql stop 3. Enter the postgres standalone backend # su postgres -c "postgres -D /var/lib/pgsql/data postgres" 4. Vacuum the database backend> vacuum full analyze 5. Exit the backend using ctrl-d (the control key plus the d key) 6. Enable AMP # enable_amp
