Verbose Logging of SNMP Configuration
To enable SNMP debug to see the traffic that is being sent to the controller during a configuration management push.
1. Enable Verbose Logging Of SNMP Configuration Under Performance Tuning Option from AMP Setup à General page.
2. Reproduce the issue by pushing out the configuration changes to the controller
3. Enter the following command from AMP CLI:
# tar -czvf snmp_debug.tar.gz /var/log/snmp_debug/
4. Send us the snmp_debug.tar.gz file and a copy of the /var/log/config_pusher log
5. Disable Verbose Logging Of SNMP Configuration Under Performance Tuning Option from AMP Setup à General page
Version history
Revision #:
1 of 1
Last update:
‎06-09-2014 09:54 AM
Updated by:
Labels (2)
Contributors
