VisualRF error if enabled 1 week after install
This is a known issue where if the customer does not enable visualRF within 1 week of installing the AMP, the /tmp folder where the site_list.xml and campus_building_list.xml are stored initially, gets cleaned out.
This has been fixed by moving the xml files to a different directory now.
Customers will keep running into this problem if they dont enable visualrf within a week from installing the AMP.
The solution is
create a directory named site_migration in /tmp
copy blank site_list.xml and campus_building_list.xml from any other AMP into the site_migration directory
restart visualRF
This should fix the issue.
The solution is
restart visualRF
The solution is
restart visualRF
Version history
Revision #:
1 of 1
Last update:
‎06-06-2014 08:04 AM
Updated by:
Labels (1)
Contributors
